tranny problems fwd
aaron207
Nov 24, 2009
Rumford, Maine
so today i pulled out for the gas station and i take off and start hearing grind noises so i pull over and it just gets worse. I go to take off and nothing happens every gear theres nothing just some bad noises. the speedo goes up when its in gear free reving. soo now i got to go get a new tranny out of this 93 eclipse n/t fwd it should fit is there a diff between a n/t & t tranny.
1. the n/t trany is not weaker it's just different gear ratios. 2. u can put the gear fluid in threw the speedo hole( the first pic). It should be just a 10mm bolt and then just wiggle out the speedo gear and pour it in threw there till it comes out the oil fill plug on the side of the trany. (second pic)
