tranny problem need help !!!!!!!!!!!!!!!!!!!!!!!!!!
dsm racer91
69
Oct 25, 2009
austin, Texas
ok so i did a clutch on my gst
everytime the car warmed up the clutch for some reason starts slipping
my rpms are around 4 to 5 grand and in 5th gear and barely going 40mph and when you put it in gear and let off the clutch the car didnt died it just idle barely
so i figure it was the pressure plate
so i did a new clutch resurface flywheel new master and slave and clutch fluid chamber but it still wont accelerate as it suppose too the rpms move way quicker and you barely are accelerating but now the car does die when you put in gear and let off the clutch
i dont know what else to do please help me :cry:
Take off the inspection cover and see if there is any oil in there. I recently had a bad slipping problem and it turned out to be my input shaft seal leaking gear oil all over my clutch system.
wheres the inspection cover located at ?
and now i drove my car for 10 15 min and now ill put the car in gear and it wont die it will just idle really ruff
whats the cause of this im thinking its something in the hydralic system but i already replaced everything
could it actually be the tranny ?
