tranny problem. help!!
dsm4life63
Jul 4, 2010
hilliard, Ohio
alright so i own a 95 gsx and second gear is pretty messed up. at low speeds it wont go in even completely stopped, sometimes it does but as soo as i let off the clutch it kicks out, but if i shift into 2nd from first above 4500 it goes in perfect with no grinds.... it wont down shift either unless i rev match which makes me think synchros but the synchros were shot on my 1g i had before this and it would shift fine into second from a stop or at lower speeds and it was at higher speeds or when i was flooring it that it would grind (but still go into gear) i checked my linkage and its fine.
Sounds like shift linkage, check the easiest stuff first... shift cables, bushings and external linkage, failing that it could be internal like the fork...
