Robert503
- 135
- 19
- Oct 19, 2008
Newberg,
Oregon
hey, i have a white 1990 eclipse AWD Turbo 175,XXX miles, and it grinds going from 1-2 and 3-2, do i just need a new syncro, fluid change? any help would be great, thanks.
Ha, I shouldn't even respond to this since everyone I have ever met from Newberg is retarded
Have you just bought the car or what? If it wasn't doing it before and it is now, did you miss a gear while driving "spirited'?
I'm going to assume that you just got the car and it's grinding so the best place to start would be a transmission fluid change. When it's draining out, make sure to take note of any metal "flakes' that are in the drain pan or anything not fluid. That is a tell tale sign of a problem either starting or been there for awhile.
Make sure you use either oem fluid from mitsubishi or high quality synthetic like Redline mt-90.
Adam
