Tranny Change Help
Tranny- new output shaft seals and use the MTX dodge lube. (like $15 a quart)
Rear tranny mount bracket (should come still on the tranny)
Manual ECU (same year as your engine)
Modular clutch and throwout bearing
Flywheel-dont know for sure but I had one so I used it.
Bolts from the flywheel to the crank (they are shorter) & possibly the ones from the flywheel to clutch.
Clutch pedal & brake pedal
Clutch master cylinder and slave cylinder
Hydralic lines. (recomend getting the complete hydralic system from the doaner car and mabye replacing any crapy lines.
Shifter/linkage
Bolts for the shifter (4) I found some that worked.
shifter boot
You do not need the axles. The old ones will work.
Shifter/linkage
shifter boot
When you say flywheel, I'm assuming you mean flexplate because the modular clutches flywheel is riveted to the actual clutch disk. The flywheel in the modular clutch assembly is then bolted to the flexplate.
