tranny and clutch problems
Mike Marnik
349
6
Mar 5, 2004
Omaha, Nebraska
Ok for the past couple of weeks now i have had no 4th gear when i go to shift into it it will go in then i let the clutch out and give it a lil gas and it pops out but all other gears are fine.
Now for the clutch i was out at the dragstrip tonight and on the first run it slipped going into 3rd then i ran again and it slipped into 2nd and 3rd and it just got worse from there i hace an act2100 with the 4 puck (it was cheaper than organic street disc). DO you think that from going from 3rd to 5th all the time has worn out the clutch or something. I have a spare tranny in my garage so i think next weekend i am going to be swapping it out for the one in there and if its not any better hopefully the parents will kick in for a rebuild but when i take the tranny off im going to check the clutch and i dont want to wait a whole week with out my car and have 2 drive the van so do you think the clutch is shot?? If it is im going to order the organic street disc. Btw i changed the clutch 3 months ago because the stock one shatterd is my tranny killing clutches. i prolly put no more than 2000 miles on it sience then. :cry:
its proly the way ur driving it that made ur clutch slip, clutches usually go up to 50g miles before they wear
