kpt4321
- 3,385
- 17
- Jul 30, 2002
sweet97 said:Torque is what gets the car moving. I is a rotational force.
Yes and no. Torque avaliable AT THE WHEELS is what gets the car moving. Horespower is basically a number that represents potential wheel torque, once gear ratio is factored in.
Torque may be the force, but when you move a car from one place to another, or you accelerate it to a certain speed, work must be done. Horsepower is work done over time, or the rate at which the motor can do work. More power means it takes a shorter amount of time to do the same work.
Dyno's cannot measure HP. They record torque and convert that to HP.
This is definately not true. Different kinds of dynos have different measurement methods, but for example a dynojet is perfectly capable of measuring power. By measuring the time differential between rotational velocities, the dyno can calculate how much energy was expended in a given time period, which is horsepower. Of course, that's also measuring acceleration, which is force, which is torque (but AT THE WHEELS).
The torque number you see on a dyno chart is the torque at the crank, which is the same thing as the torque at the wheels with a 1.00:1 gear ratio. The torque number on a dyno chart is NOT NOT NOT the torque that is avaliable at the wheels, which is by far the only thing that matters.
A Dyno Dynamics dyno measures the "tractive force" avaliable at the tire, which can be translated to wheel torque when a few other factors are known. From there you can solve for horsepower, and from there you can get the crank torque number shown on the dyno chart.
