1G Top radiator hose leak
Moovingon1GEclipse
3
Jan 28, 2022
Beja, Europe
So on the connection of the radiator top hose I had spot where it was dripping a little bit of coolant (radiator to engine hose) and i put some silicone for oil and maintenance fluids as a quick fix for now, while i wait for a new hose. Should i avoid using the car to the max or a soon as it dries out it will hold without any worries(it says +350°c) ? I recon it's not the best but it's pouring like hell and it's a sunday so not much i could actually do since in my country finding parts for car like theese will take me a minimum of 2 weeks to get. I know that I can't drive it hard otherwise in can cause to much pressure on it. But it was just a small dripping.
Any advice ? As soon as the rain dies I'll post some pictures.
I doubt silicone sealant will do much to prevent a leak from leaking. Sounds like just a small leak to begin with, so drive sparingly, but I wouldn’t worry too much if you will have a replacement hose in a week or two. The pressure in the cooling system is entirely related to temperature and proportion of water to ethylene glycol. A good 50/50 mix will have a much higher boiling point, and therefore lower vapor pressure for a given temperature. Carry a roll of duct tape in the car in case it starts to rupture. Might get you home, or at least back to a place you can safely park.
Here are some photos from it taken today. I know it was rough patch but yesterday was pouring and i cleaned it up and nade it more even today. Will do a test run tomorrow to see if it still leaks since it was dripping from only being on iddling. It was around 1 drop every 10 seconds but if i pushed the throttle cable it would drop a bit more.
