2G Radiator hose location
Ezylpro
8
Sep 22, 2025
Joinville, South America
Hey! I'm a bit of a newbie here, so sorry for giving not much context. I had a leak on a radiator hose, and decided to buy an aliexpress 11pc kit, but I'm not sure where each one of them are located. Is there a diagram, or something that I can take a look to find each one of the hose's location? I can post the link of the hose kit here if it helps, just not sure if its allowed.
If you searched and there wasn't a diagram anywhere starting from the left the first one is the lower radiator hose the next one is the upper. You'll need to match the 2 that fit your turbo coolant lines which will be the smaller ones. The last 2 are your heater core hoses. There are some under the car that go into your oil filter housing also. You will need to cut them down if there anything like the ones I bought on ebay. Just go slow and take one off at a time and match them up. I did a little digging for you and I did see a video but it's on Facebook which I do not have.
