Took off my manifold now rad fluid leaking like crazy!
KillerX
60
May 27, 2006
Strathroy,
ok so I took off the manifold and now rad fluid is leaking like crazy? my question is what is this line called...where can I get it? where does it even go to? I couldent see because it was leakin like a waterfall!
its the actual line thats connected to that big bolt...
Brad
Thats the coolant return line for the turbo. It goes to the water pipe. Your best bet is to find someone with a extra turbo water pipe.
andymoraitis said:
Pick up some vacuum hose from a local Napa, cut a section and put it back on. Two minute job at worst.
Andy
hmmm ya know what i probably could do that and then just use gear clamps over the existing thing... hmmm that way it wont rust as well... but ya think ill have to take out the turbo?
Brad
