too much injector?
mechanix565
165
Apr 19, 2009
Pawtucket, Rhode Island
simple question i have a stock longblock 7 bolt w/ bolt ons but i dont want to buy injectors twice a friend of mine has a set of 850cc injectors i can get cheap can i run them im my car and will they just run at a low duty cycle? i have a flashable ecu and ecu flash. will the car run fine with that big of an injector on a 190 pump and stock fuel lines and rail? i just want a set of injectors that i can grow with. thanks.
Yes, you will be ok with those injectors with ecuflash; I've run twice that with very little affect on driveability. You'll want to get a wideband or have it tuned asap, but you shouldn't have any issues with just scaling the injectors.
You'll be fine with evoscan and ecuflash. You can essentially run any injector. It is also very easy to scale them with ecuflash, coming from the evo world as well. Just make sure you use a wideband and evoscan and you'll have it driving just as good as stock in no time. If you are unfamiliar with how to do this, shoot me a PM and I would be glad to help.
Jon
