Too much fuel.
white92talontsi
979
9
Nov 12, 2003
Fayetteville, North Carolina
Running a 3.5" gm maf and maft 2.01.
650cc injectors.
Not sure about the pump but I can hear it outside the car.
With the maft set at aux of 1 and a base of 7 for 650's.
Setup like this I have to run the mid and wot knobs full lean. No more I can take out and the car is still running rich. Wondering if I should change to the table for 700's. Like I said fuel pump is unknown. It could be a 255 and overrunning the fpr.
Any suggestions?
Sent from my PC36100 using Tapatalk
what brand injectors are they? do you have the dip switches set right? gm 3.5inch is set different than gm 3 in. and if you can check the fuel pres. just a couple of thoughts
FIC 650's. Have dipswitch 1 on the rest off for 3.5"
I need to check fuel pressure but can't buy a fpr til a few weeks.
Poor guy here. Lol.
I think I finally figured this problem out. It seems that the o2 is not heating up like it should.
In order to get the Air fuel in spec I have to make a hard pull to heat the o2 up and then the A/F ratio will then start to level off like it should.
Plan to check wiring to the heater and then check the o2.
