To reuse pressure plate or not to?
Blaze4G63
191
May 30, 2008
NW, Washington
Long story short Im putting my clutch all back together after having swapped an engine and the clutch disk is almost brand new, i know this because I measured the thickness with some brand new digital calipers. Its a act 2600 and it measures 8cm so i know thats good, but the pressure plate seems to be in less then good shape. I dont know if its ok to reuse or not. Heres some pictures im going to see if its warped when i get home from work.
When in doubt replace it, pictures don't show up but by your description of it looking "not so good" I wouldn't put it back in my car.
Why risk having to do it all over again? Just replace it. Youll be glad u did when you dont have to pull the trans again.
And you want to talk about hp. I had a saturn sl2 maybe making 110 hp maybe. The po did his own clutch job and smashed the fingers on the pressure plate. When I bought it he gave me the old pressure plate. So I decided to use the old pressure plate with the new disk and it lasted 2 days on a nt saturn making 110 hp at best. And my pressure plate looked better then the op pressure plate dose.
