To Lean? Need Help! Problem!
NeOzz1
210
Oct 29, 2003
Wellington, Ohio
DO NOT CROSS-POST. EVER.
OK i definetly have a problem. First I raced a car that has only run 15.1 or 15.2 tops ever and nothings has changed on it. I have 15 or 16 psi, a higflow cat, filter, and new plugs and wires. I am not positive but i think a should have beet him but I didn't, I was 2 or three cars behind him and it was at least a 1/4 run. Anyways thats the first problem, shouldn't I be faster then that? Ok second sometimes when I start my car it stutters and does not want to run for a bit till I rev it up a few times. could that be a cause of running lean maybe and could that also be why I am not as fats as expected? I am not sure how i could be running lean unless its because of the free mod of taking out your lower honeycomb. I am not sure whats goin on but i defitnetly need some questions answered so please help me!
Thanks,
Justin:talon:
Sry if I am just freakin out over nothing but this stuff is driving me crazy, if everything is normaljust let me know please.
You wouldn't happen to be venting your BOV to atmosphere, would you?
Pushin 16psi with a less restrictiv exhaust should put you better than a 15 in the 1/4.
But what did you launch like? Was it a good launch? Did you have wheel spin?
Sputterin during startup could be alot of things. You could have clogged injectors, causing lean symptoms.
Do you experance a miss fire? How old are your plug wires? There are alot of things that you have to asses before you can come up with a solution for being to slow. LOL
wires are brand new and i didn't run at the quarter i raced someone that runs 15.1's and lost
So is the spark plugs changed too I'd imagine? If so look into that.
Even on this site a 90 TSi AWD with just intake is a 15 second car...so either its:
a) something is wrong with your car
b) this rival is lying to you
c) driver error
1. yes plugs are new too
2. i have people i trust that know his times are true
3. i dont think it could have been a driver error because its auto so there is not much room for error
