To all fabricators
junkyardgsx
49
Aug 11, 2010
Phoenix, Arizona
First off this post sounds kind of rude, and I do not intend it to be this way. I want to know some basic why and why nots LOL. Who here is a fabricator? I want to know what you guys build, for your cars or others. You see my 1G suffers from one area that hardly has R&D applied, Suspension Components. Has anybody ever gone further than the control arms? 2G cars get all the goodies, Tubular control arms, billet spindles, even tubular sub-frames that are adjustable! I want some of this for my old 1G because the Evolutions and STI's walk all over us at the track. Maybe I need to buy a 2G car and start over, but I like my 1G body style more and would like a competitive car. Gixxerdrew amazes me with the R&D he has done to his eclipse, and he shares tips with us in his blogs, so can we please put some of it to use?
Well... I'm not a total fabricator of any means just a novice hobbiest weldor.
The 1g and 2g suspensions are two totally different animals.
On a 2g you've got a lower and an upper control arm then a spring and shock combination. This means there are more parts to a 2g suspension that could be modified.
Whereas on the 1g you've got a McPherson strut type suspension where there is only a lower control arm and a strut. There's only so many parts on the 1g's suspension that you can modify. Now, probably the most improvement we could make would be on the rear suspension and how it functions. I would love to have castor adjustment on the front end. But the plates i have on the front only allow for camber adjustment. My castor is off by 1* on the front end which makes it pull to the right. Camber and toe are within my specs.
So, short of swapping out the entire suspension for something else... I don't see many parts being developed for the 1g...
I contacted Robi Spec, and they can alter the roll center, as well as offer EVO coilovers modified for our cars, which i have seen before. The rear suspension is a poor designed unit I agree. I found a fabricator here in Phoenix AZ that builds off-road trucks and also rally cars. He has built a back-halved Imprezza, meaning the sub-frame was custom built out of tubular chromoly steel. I don't know if I want the back-half, but i would like a tubular sub-frame for one, weight savings, 2 every arm could be made adjustable as well as geometry improved. he quoted me from $1500 to $2500, depending how much adjustment I want. I showed him a sub-frame picture and he can easily duplicate it, looking at a Trophy Truck outside his shop makes me not doubt him.
I'd see no reason why you couldn't custom make double wishbone on all 4 corners. It would be a lot of work and fab, but the results would be worth it, and it's good research for others to follow.
After reading about the Revolution RX7, it makes me want to do a double wishbone on all for corners! This car has converted a MacPherson Strut car into a double wishbone car, as well as Full Race here in Phoenix on their R14 AWD 240SX! As much as I would love to do this, I believe our true problems lie in the rear suspension, and I am going to be focusing on that area first. However, do you guys think it is more feasible since it will all be custom to use EVO 8 knuckles, and hubs or 2G AWD knuckles and hubs for the rear? Another question, are all 2G front knuckles/hubs the same between GST-GSX and RS? I know where I can get a set of hubs for cheap, but I don't know if its a GST or GSX. I can make a cardboard blue-print as in the fabrication thread stated, just to see how much geometry changes are needed. I wouldn't mind tubbing the front end of the car, in exchange for a Double Wish bone set-up :hellyeah:
