Tissue paper in the oil filter housing :(
Lionel Hutz
48
Oct 31, 2004
Mississauga,
I was installing the oil feed lines for my new T04b today. I plugged off the hole on the oil filter housing with a little bit of paper towel so no crap would get in because I was removing the sensor next to it. I think a little bit of tissue paper got ripped off when I was pulling it out. Should I worry about this clogging the oil feed lines? I can't see it but I'm pretty sure it's in there. How could I flush it out? :D
you can use compressed air or get a can of compressed air you use to clean your computer and disconnect the end of the hose and blow it out. i think i understand where you tore it off at. So you can take out the sensor and have the oil filter off, then blow it out, good luck Depending which passage it is you could start the car for a few seconds and let the oil shoot it out
