Tire height question.
A_USER_NAME
148
27
Aug 9, 2012
Sahuarita, Arizona
Sitting around talking cars and a buddy of mine insists that a 225/45-18 on an 8" wide rim will be as tall as the same tire on a 7.5" wide rim. Reason the convo came ip is because I picked up these rims dirt cheap but they are 18x8 and 18x7.5. I know I can't run them unless the tire circumference is the same. But he insists the circumference will be the same.
With that being said wouldn't the overall tire height be slightly shorter on the 18x8?
Am I just missing something here?
They should be the same height. The only variance would come from the tire being stretched a bit more on the wider wheel.
This. How much different though, I don't know.
This. Exactly my point, a tire that is stretched more will be shorter. As stated though I figured it wouldn't make much of a difference, if I wanter to I could add more air to the wider rim and im sure it would be close to the same. Thanks for the replies, just an odd though.
