turboglenn
- 6,375
- 124
- Nov 5, 2007
RIpley,
West Virginia
Anyone got any tricks or tips to make the install easier? I've become quite fast at the FWD over the years but the AWD seams to be a whole new bear when it comes to lining it up and getting the input shaft into the friction disk and the bolts started.. the rear of it where it hits the front subframe is the main issue.. I usually leave the mount on the rear on the sub frame and just unbolt the 3 17mm bolts fro the trans body, then up front i seperate the front roll stop and pull the front member down as well and the top mount i unbolt from the verticle bolts and then rotatte the mount up and out of the way, but i just can't seem to find anything that makes putting this bi*** up in there go any faster or smoother..some long time AWD guys gimme some tips please!!!!!!!
Got my Flywheel torqued and red loc-tited in from it coming loose earlier today (see thread about noise in thise section) but now it's time to wrestle that beast up in there again and i'm almost feeling defeate before i start again...
Should it go in perfect level or maybe be rocked in back end first or what... there has to be something to making it faster/easier.. once that's in the rest is cake IMO, just getting it up to the engine and bolted down seems like the impossible task and where 90% of the man hours on a trans R&R come from
edit; nevermind, i must type in invisible ink.. not even one view on my post from this morning
,. well I got all the issues solved, trans back in, all hooked up and ready to drive again..........thnks anyway!
on the floor again
