4g63swap
- 258
- 0
- Aug 9, 2003
but the timming belt on yeasterday when I set all the gears to there timing mark and properly put the timmint belt on I went to rotate it 6 times to get the tensionor set right and one of my valves were hittin a piston. so I found tdc of #1 and set it that way. is this going to couse any timming problems?
thanks
thanks
if you don't think that is part of his sig you truly are missing something........
