Timing belt problems
GILZTSIAWD
748
11
Feb 4, 2004
petal, Mississippi
I decided to change out my timing belt, but when i looked at the crankshaft and oil pump pulley's i realized that they are both off by 1 tooth when i line up the camshaft pulleys. someone has obviously changed out the timing belt before as there was cover bolts missing and etc. So do you think that i should leave it the way it is or turn the pulleys back to the marks like they are supposed to be? Did they maybe retard or advance the timing for performance?
Thanx in advance
Gil
