2GbRS
- 0
- Nov 28, 2009
washougal,
Washington
i keep installing the belt as the book says, half a tooth btdc around the water pump up arount the idler pulley around the gears back around the tensioner pulley then rotate crank to tdc to pull the slack then apply whatever ft lbs on the tensioner pulley and install the plunger.. pull pin out back in and out and every time i'm off by a half a tooth on the crank after 2 revolutions on the crank..
pissing me the #### off, anyone have an idea whats up?
