Throttle body wire???
gsxrtalon
395
Apr 23, 2005
Harrison, Michigan
I have a 6bolt swap in my GSX and I have noticed something on my throttle body. My wiring for the 6 bolt runs by my throttle body and there is a wire coming out of the bundle of wires that goes to something on my throttle body. Can someone inform me as to what this is? Its importance and what-not. Thanks
ok soo I think this wire was hooked up to this plug then I think it came off. Do I need to hook it back up or no? I believe this is a 1g throttle body(not sure) and when I bought the car it had the 6bolt swap done. I believe the 2g TPS is switched over, maybe not. Any help would be great. Thanks
Heres another picture from the other side.
Isn't that the throttle body butterfly? It's only use is to hold the throttle cable in place? The big metal clip in the middle of the picture is the throttle stop sensor. Unplug your TPS and check if there are 4 pins instead of 3 to verify that it is a 2g TPS.
sorry for the ?'s but where exactly is the TPS I believe I know but just wondering?Thanks
Yes, the metal clip is what the wire was running to.
I found the TPS, there is a bunch of wiring keeping me from getting at it at the right angle to unplug it. It looked like I could see 3 wires going into the plug though. The top half of the plug is red, if that matters.
  • Wanted 2g Test Pipe/Straight Pipe
    Just wondering if anyone has a test pipe that replaces the stock cat for sale. No preference for...
    • DankYeezy
  • Wanted 4G63 Ecu 1g 1991-1994 Eprom socketed
    Wtb Ecu 1g 1991-1994 Eprom socketed in good working condition!
    • niki_talon
  • For sale 4G63 Stainless T3 header w/38mm wastegate flange
    Same header you can get for $230 on eBay. Like new, only ran for 10min or so. Price is shipped...
    • GRNDSM
    • dsmmario
