throtle body problem
zrk666
144
May 13, 2004
louisville, Kentucky
last night i go to change the throtle body on my 90 awd with a talon 91 awd because the ISC idle speed control was going bad and was easyier than just changing the ISC motor. i get both throtle bodies off switch them hoock all the vacuum lines up the way they were and the sensor connections. i get completly done bolt the ic hoses and get every thing the way it was.
i turn the key to start it and all it does is turn the motor over. doesnt act like it is going to start or anything. check the fuel pump, fuses, vacuum hoses and etc.
sense it doesnt start i switch the original back on and now it soesnt want to start again.
it ran right before i took the throtle body off so i have no ideas and i need my car to go to school and work so i am in a bind if i cant get it fixed this weeekend.
any one have any ideas?
The 90 TB has different sensors connectors and location, how did you modified your 90 harness to accommodate the 91 TB?
it bolted and pluged in the same exact place. i did no modifications to anything. it could of been an early 91 or late 90 not sure. i am fixing it with a couple friends to seel to make a profit.
