Thoughts and Reactions for TD05 20g
weegee411
67
Sep 14, 2008
Pueblo, Colorado
I just purchased a td05 20g turbo and hoping to install the bad boy soon :hellyeah: I was hoping to get some input from people who have ran this turbo about the good and bad about the turbo and how they like it. I have 272 cams, 3" exhaust, 2.5" I/C piping and greddy FMIC, and all supporting fuel mods. the car will be a DD at 10psi and a track runner at 28psi hopefully.
Search man, there are plenty of threads about this turbo. I know of 2 of them that are active and have posted in them today.
Don't waste your time at 10psi with a 20G. Dial the car for 25-28psi and leave it there....it sure saves a lot of screwing around. You're not going to blow it up by running high boost daily if you have a good tune and plenty of supporting mods.
The TD05H 20G is my favorite turbo for any street-driven DSM. No other turbo spools as quick and has the same reliability while making 42+lb/min of airflow.
I had a td05h 20g on my car for a while at 30psi and loved it. It was a lot off fun! full boost by like 3800 and great torque. dsmlink read a 1.82 70-90 time on pump gas which "should" be good for 120-125 trap speed:hellyeah: Never got to run it at the track at 30psi though. And like jusmx141 said dont bother with 10psi, just dial it in correctly at high boost and call it a day. You will be much happier.
I am running the td05 ,20g ,@18psi and it spools great car pulles hard . now my buddy runs the 20g,td06 and that turbo pulls harder than mine .he is at full boost @3200rpm with a built head and motor and 258 comp cam,s . you will be very happy with this turbo .:D
  • Wanted 6 bolt NT water pipe
    • chrisman287
