this is weird
lou schmouder
271
Jun 17, 2008
dalton, Georgia
My eclipse will not crank with alt plugged in.I can start car with it unplugged then plug it in and my battery goes up to 13.98 but my power post gets hot. Also may not matter but , after 4k rpm its backfireing or misfireing. advance tested my alt 15 time becaused it failed the frist but passed all the other 14 times. This is crazy could my belt be to tight???? please help
i had a similar problem and my car wouldnt rev very high, very hard to get it to start, i had faulty wiring on my Coil on plug setup. I had to get an obdII reader to determine my problem
multiple cylinder misfire, i just rewired all the wires underneath my coilpacks, and it fixed the problem. I would go to rev it up in neutral and it wouldnt rev past 4500 rpms. It was like hitting the rev limiter. then a day later i would try to start it and it would barely start then it would idle really rough and then die.
