this blows! broke caliper bolts
Eclipse90GSX
149
Oct 13, 2002
Arlington, Texas
okay guys here;s the deal
u guys know the 2 14mm bolts that hold the mounting brakcet onto the hub? well the head on the top one broke.
is the hub threaded? if not i may still be able to slide it off the hub and throw away the caliper mounting bracket with the broken threaded bolt in it still....
anyone know?? argh this blows :mad: :mad: :mad:
Yes, that is the way it would be. The bolt would be broken in the carrier.
Be carefull about the replacement tho...I think some of the early 90's had a standalone interchange....
The good news is you'll be mobile soon.
Please close your other thread.
Thanks.
thanks for the info...hopefully it'll slide right out of the hub cause its not threaded.
As for the other thread I shall close it right after i take out my old caliper+rotor and take pics. I will then edit that post with those last pics i take to show everyone what carnage bad rotor and caliper installations will do. I will then close it thereafter.
thanks again :coy:
