things i did to my dsm in southern california today.
Cause Turbo lab make me sad... They lagging... Ordered the part Wednesday and still not shipped... Very disappointed with service so far.
Tuesday - Windshield gets put in!
Hot side + smog = 2013 plates.
Laid down some very much needed test passes at barona today, prepped my street car for its freshly rebuilt head:thumb:
The TSi is running again thanks to the help of Mike. I found an oil leak, the coolant is leaking like crazy, the Gas Pedal is really stiff, clutch is a little soft, but other then that she is a beast. More pics and post to come in the future.
Pics below
Headlights before I restored the.
Out with the old windshield.
In with the new Windshield.
Evo 3 16G Turbo set up in. Thumbs up from Mike
The Talon put back together!
** I also put air in all tires and cleaned the interior with my vacuum. **
Installed a 2g speed sensor into the Dragon. up next tomorrow will be to finish the wiring for the gauges and continue to drive her into the dirt. oh and it breaks the stock gst wheels loose like a stock gst would now
Installed a new ACT flywheel and a 2900 6 puck sprung clutch in my GSX last night.
... :applause:
Anyone can break bicycle tires loose too by just pedaling fast and leaning over the handle bars. LOL
:dsm:
I fixed my E-Brake on the TSi this morning after I woke up. Removed the console to find out I didn't need to... The E-Brake was really loose and I tightened the Cable stud nut thing. E-Brake is now tight and stops the car as it moves.
Got the tranny in the GSX, got the o2 and wideband bungs welded on (in a bad spot) so I need a ALT relocation kit now. Installed the coil overs.
Put on the Exhaust gasket and got hit in the eye with a hammer and hit with a heavy metal breaker bar in the mouth/teeth area... Thanks Sal!!!
Sal and Mike helped me get the boost gauge on yesterday to find out I have a worse vac leak than expected!!
Put my Pod on this morning, broke a drill bit and reset my check engine error hahaha...
redid all the brakes rotated tires. playing with all my controlls trying to get the settings right. DOES anyone have some front struts and springs for a 1g?
I have some strut/spring set for a 1g AWD but they will lower your car about 1.5 inches.
Changed the oil and fixed the coolant leak, 2 hoses broke. Swapped new ones on and added new clamps. Called it a day for the engine so far.
Also got the boost gauge installed.
Removed my crappy rear blurry tint.
removed the honey comb out my intake car picks up quicker finished laying my first coat of undercoat on the inside of car (its almost fully gutted) spraying the whole insdie a matt black then putting in a roll cage hear soon
Got my new POD in the mail today and installed it.
Sal found a leak in the boost gauge set up and fixed it.
Found out my http://members.shaw.ca/dsm.1000q/Engineprimer/2G/mdp.htm needs to be replaced. Found a CEL thanks to Sal!
Removed the Strut bars off my RS and then I spiraled the Electrical tape to make a design on the strut bar LOL... Also put the Rear Strut bar in...
