The water line that attaches to the block goes to front or back of evo3?
focusedrage
1,053
Aug 3, 2002
Laytonsville, Maryland
Just like the title says, i have replaced my lines with stainless ones, and i forgot which goes where...
There is a line that runs to the block, and one that runs to pipe that runs across the front of the block, i want to know if the line that goes into the block attaches to the front or back of the evo3 16g
man i realy need this info, i looked around and the pics are so vauge, does it even matter if im running my own lines? i would like to install tommow
The line that comes from the big line from behind the turbo attached to the front/radiator side of the turbo.
To the left of the turbo are 2 lines that attached to steel lines. One is for a line that also runs behind the block, with one for the back side of the turbo. Mark
F my wording is vageu email again!
it is a little vauge, all i want to know is if the steal line that is banjo nuted into the block, which then goes to rubber line, which then goes back to steel likne on the turbo.... which side does this connecto. rember this is directly to the block.
I just went out and looked at my motor. The line that comes from the head is the oil inlet to the turbo. This is connected pight at the far left and close to the front on the head. I have a braided line so Idon't use that location anymore. Not sure what you mean "which side it attahes to" Give me some more info and I will check my motor for you. mark
first off this is on a 2g.... now there is a water line that goes into the physical block, i want to know if that line attaches to the engine side or radiator side of the evo3 16g
ah ok, so it looks like the block line attaches to the front of the turbo and that line in the first pic goes to the back of the turbo. i wish a wiseman would chime in, cause it just seems like it might not matter, cause water is flowing through the center part either way, but i still want to be sure
here is a photo that i had of my own car. now notice where the thermostat housing goes... and under it is the o2sensor plug, now to the right of it is a small tube, which connects to the big tube, this is one turbo connection.
now to the imediate south east of that, is another tube pointing down, i belive that that tube is conencted to the block. this is another turbo connection. which goes where, thanks.
