The Start Parts and Pics
MY1GDSM
3,213
50
Apr 26, 2007
On the beach, Washington
Parts list/Stuff Done:
(Probably forgetting a bunch of little stuff)
Southbend 8puck Ceramic clutch & SS-x PP
New OEM TOB
FIC Bluemax 1450's
New Injector O-rings
All new trans t-case rear dif. fluids (Redline)
Shifter bushings (Skate bearings)
Sub-frame Bushing
Front End Control Arm Bushing set
Front Sway Bar Frame Bushings
Rear Sway Bar Frame / Track Arm Bushings
Rear End Control Arm Bushing~ Ran out of time
Tie rod ends
New Turbo oil filter
Exhaust Wraped
New -6an Fuel feed lines &
Trick flow fuel filter
Curved front Cross member from Vassil
New T-case yoke and seals
New 215/45/17 Falkon Fk-452 Tires
4 Wheel Alignment
Please ignore the before pic a bunch
I haven't done anything besides maintenance for a few years Also:The Map sensor I have just pulled LOL
Pics:
Before
Motor Pulled
Dropped Subframe
Subframe cleaned up an back in, and new Front Cross member painted an in...
Cracked Cam Gear
Harness Out
Car side soldered an fixed from previous AFC's Et cedra
Finished
Thanks, I've got a couple other better pic I should find an put up ...
But Old engine? Not sure if I know what you mean... you mean the same one that came out?
Cause I've had this same motor together for about a little over 3 years since I rebuilt it...
I Just pulled everything so it would be easier to get to everything an drop the sub-frame & do the clutch.
Plus I had that cracked cam gear an It's so much quicker to do the T-belt with the engine out.
I thought you were telling us that you had another engine you were putting in..The one you just picked up parts from the machine shop for..Maybe that's for the other car then..I bet it's easier to do a T belt with the engine out..Not so much a PITA..
I kinda know how this feels. Thats the way my Eclipse looked up until this last year and I decided to donate its exterior parts to a Talon!
