The lancer.
the_eclipse_1
36
Dec 8, 2002
Cold Spring, Kentucky
Okay I've got a buddy were looking to turbo his 2003 lancer oz edition rather nice its all stock and i don't know much about his motor since my eclipse has the awwing 420a in it. Don't the lances come with the 4g94 i think it is. but we want to start work on his car since mine is dead again. thats the last time i let my ex-girlfriend drive anything that i own. boost controllers are great for someone who knows how to use it but for someone that think 23 psi isn't that much problems are bound to happen. so i'm looking for parts let me know were some good places are to go thanks dudes and dudets. yes i realize i just call you all a hair on a elephants ass but hey. :cool:
the 03 lancer has the 4g63 engine in it that might help you get started, as for turboing it i'm thinkin it'd be similar to doing any 2g n/a-t conversion.
theres a evo site if you scroll to bottom of forum page if youd try that.
just stop right there and don't post any further
www.cars.com
read and learn then come back with positive information in which you are able to assist in someones knowledge and not hinder it and look unknowing your self.
2003 lancer oz edition is a 2.4L 168hp car, last time i checked, only stroker 4g63's made 2.4L, also....last time i checked, there hasnt been an NA 4g63 since the 1g dsm was no more...
The engine code is 4G64 (2.4L). The same as in the 2000+ eclipse. The blocks are almost the same, big difference in the head though, and the way the engine sits in the car. When I had my 2000+ eclipse I looked into puting a turbo on it, but saw how much it was going to cost. In the area of 4K. Tell your friend to sell his car and buy a kick ass AWD 1G like I did. I have never looked back........ well that isnt true. I do miss a car I dont have to worry about starting up in the morning. :)
Oh crap never mind! He has a 2.0. The Ralli Art has the 2.4L
ENGINE
ES
LS
OZ RALLY
RALLIART
Engine Type
2.0 Liter SOHC inline-4
2.4 MIVEC SOHC in-line-4
Engine Code
4G94
4G69
Valve Train
SOHC, 4-valves per cylinder
Displacement (cu. in./cc.)
1999 / 122
2378 / 145
Bore x Stroke (in./mm)
3.21 X 3.77 / 81.5 X 95.8
3.43 X 3.94 / 87.0 X 100.0
Compression Ratio
9.5 : 1
9.5 : 1
Horsepower @ RPM (BHP)
120 @ 5500
162 @ 5750
Torque @ RPM (lbs-ft)
130 @ 4250
162 @ 4000
Engine Block
Cast Iron
Cast Iron
Cylinder Heads
Aluminum
Aluminum
Redline RPM
6000 RPM
6500 RPM
Valve Cover
Steel
Aluminum
Fuel System
Electronically-controlled, multi-point injection
Recommended Fuel
Regular
Radiator Core size (mm)
700 x 375 x 16
700 x 375 x 27
Engine Oil Type
Mineral Oil
Engine Oil Capacity (qt/L)
4.0 / 3.8
4.5 qt / 4.3 L
TRANSMISSION
ES
LS
OZ RALLY
RALLIART
Drive Train
2WD
2WD
5MT
4AT
4AT
5MT
1st
3.583
2.842
2.842
3.583
2nd
1.947
1.529
1.529
1.947
3rd
1.379
1.000
1.000
1.379
4th
1.03
0.712
0.712
1.030
5th
0.767
0.820
Reverse
3.363
2.480
2.480
3.363
Final Drive Ratio
3.722
4.041
4.041
4.058
SUSPENSION
ES
LS
OZ RALLY
RALLIART
Front
Independent MacPherson Strut
Front Stabilizer Bar Diameter (mm)
24
26
Front Strut Tower Brace
STD
Rear
Independent Multi-link w/ Coil Springs
Rear Stabilizer Bar Diameter (mm)
13
13
EXTERIOR DIMENSIONS
ES
LS
OZ RALLY
RALLIART
Wheelbase (in/mm)
102.4 in / 2600 mm
Length (in/mm)
180.5 in / 4585 mm
Width (in/mm)
66.8 in / 1695 mm
http://66.102.7.104/search?q=cache:...11/11/172656.html+engine+code+oz+lancer&hl=en
