Resolved Tell me these wires (wire tuck)
Mark4g63t
294
6
Jan 21, 2010
Minneapolis, Minnesota
Hey guys I need some help, I over excitedly took off the tape on some of my plugs on the fuse box harness and can't remember where they went .
I need to know where these 2 plugs, plug into.
Both are single wires, and are very long. One is white and one is white with a black stripe. They go back to the fuse box. If I traced them correctly they go to the Ignition fuse and the fuse(+B)
Thsnks
Thsnks
Pretty sure that one of them plugs into the back of the interior fuse box in the drivers side footwell, and the other one plugs in right above the interior fuse box. You can get to the connector through the grommet under the drivers side fender. Which one is which i cant remember off the top of my head
I will take a look.
well no luck yet, wondering if they connect to the other harness (that is still out of the car)
Looked some more and found one might be for a sunroof.. I never had one but maybe it's still wired?
Here are pictures from my notes. Look for interior E (fuse 1) and Fuse 16.
Awesome! Thank you! Got them both figured out! Both connect right behind the dash, accessed through the hole behind the fender. One goes to a yellow connector and one to a black connector attached to the dash. They can not be mixed up as the pattern on the plugs are different.
