Tee OIl Feed fitting CAn't find it?? please help
BeClipse
39
May 29, 2004
alexandria, Virginia
I'm trying to prep everythign for my turbo. So today i took the oil sending unit out. i measured it and it was 18 mm. I went to get a Tee fiiting but nobody has a 18mm tee. Lowes has a lot of fittings but they are all standart. If anybody know where in the USA can I get a tee fitting that would fit my oil sending unit I would deeply appreciate it thanks guys ya been awsome. i find a lot of help on here. So please let me know about this one I'm getting desperate.
PS: I checked LOWES, autozone, o'reilly, advance auto, even ebay or the internet.
BeClipse said:
do you know what size was it. maybe i measured it wrong????
There is no MM measurment for the sending unit. You need to be talking NPT sizes. I'm not sure but I believe it is a 1/4" NPT fittimg that you will need the T for. Then you will need a reducer to take the 1/4" T down to an 1/8" NPT for your turbo feed line. If you have the oil sensor then take it to the store and size it up on location, that is the best way to get what you need.
yeah man go to home depot ... take the sending unit with you there ...and try to find the same size male to female i think it's 5/8 then u need a reducer to whatever size feed line u using i believe 1/4 is the size but go to home dopot that's the spot looke for compressed fitting its a gold color..
