TD05H, is this a 16g big turbo!
That's pretty much it. You have to look at the compressor blades.
This is a 16G.
Here's the best comparison I could find of the compressor blades with a shot of the 14B. The 14B has flat blades, 16G has stepped, as stated earlier.
It looks like the 16G and 14B have the same size compressor housing. Is the interior of the 16G compressor housing larger in diameter than the inside of the 14B compressor housing?
Thanks for the pics. A little turbo 101 please...so the 2vain fins have better flow than the single vain? But the single vain has more fins.
No. They are both TD05H compressor housings, exactly the same internally. The only difference being the size of the compressor wheel - the small 16G is larger than the 14B, the big 16G is larger than the small 16G, etc.
It looks like the 16G only has 6 fins, but actually, they both have 12 fins. It's just that some are smaller and some are larger on the G-series Mitsubishi turbos (13G, 16G, 20G, etc).
Also, most 16G's are equipped with Mitsubishi 7cm2 turbine housings, while stock 14B's have 6cm2 housings. This allows more exhaust flow (and therefore is less restrictive as far as top-end power), at the expense of a little more turbo lag.
The 16g housing has to be machined inside because the wheel is a little bit bigger.
Interesting! You know, I actually wondered about that after maybe 10 minutes after I posted that. Thanks for the info and clearing that up. :)
the 16G has a larger turbine wheel to accompany the larger turbine housing, compared to the 14b turbine wheel.. correct? or are they the same turbine wheel?
  • Wanted 6 bolt NT water pipe
    • chrisman287
