tb advice
FirstDSMTimer
75
Jun 26, 2011
Baltimore, Maryland
I am looking at a 90 n/t throttle body and i am curious if i would be able to use the iac on that in my 2g or should i just try to find a 1g turbo tb and find a 2g elbow? I had a 1g n/t with a bad iac and the bolt broke off in it and i tried to extract it and it also broke off in it so its time to replace it.
You could use the n/t or 1g, they both are bigger than the 52mm 2g throttle body. Either 1g or 2g elbows will work but u half to port the 2g one to match the throttle body. Won`t make a huge difference unless ## running high boost levels though.
I boring out your existing throttle body would achieve what you want. Throttlebodys.Com will bore out 1G and 2G throttle bodies.
They did a great job rebuilding my stock throttle body.
