TB question
Ernie D
73
Aug 25, 2012
Westlake, Louisiana
I'm pretty sure this got brought up before but I tried doing a search but found a few threads close but not quite what I was asking.
I went to a nearby pull-a-part because they had a couple of 1g cars there, I didn't know weather they were N/T cars or turbo cars. Which when I got there they had three and all N/T cars
I got the TB's off of two of them as spares not thinking they had the intake pipe flange on the casting.
My question is can I use a N/T TB on a turbo car because the turbo TB I have is a 2g model (smaller bore) ? I'll just have to get another silicone elbow to make up for the metal elbow
Any advice is appreciated
I would reccomend you rebuild it with new shaft seals at least and use your 4 pin 2g TPS.
I was planning on rebuilding it before I install it, where would be the best place to get the seals from? I'm also planning on using a FIAV Bypass Plate from FFWD connection to eliminate the need for the coolant lines.
