Tail light problem pic included
P3Kans DSM
286
Aug 4, 2010
The Harbor, Illinois
Alright guys ive searched and searched and i cant find it anywhere. My rear turn signals dont work. The front ones along with the front hazards work fine. Just the rear. Brake lights light up fine and work when the brake is depressed, just no rear turn signals. Im pretty sure its the hacked wiring but i cant figure out how it goes so ive included pix.. thanks for any help
The 1st pic is the tails on my car.
The 2nd pic is the harness. Theres only 3 a green, green/white, and black. But from the car theres green, green/white, green/yellow, and black.
I would check the fuse first and make sure the bulbs aren't burnt out. But if there is disconnected/hacked wiring that might be the problem and I can't help you there as I don't know 1G's. Check the other two things first if you haven't.
EDIT:
Also if you have either the factory manual or a Haynes/Chilton, might check the wiring diagrams there.
