t3/t4 will it bolt to my 95 gsx manifold?
no that will not directly bolt up to a stock mitsu manifold. but i think there is a spacer adaper for turbo's like that.
im new to the whole turbo thing. i have always ran n/a cars, what all is needed to install a 16 g on a 2g eclipse? will it bolt directly to the manifold? what all is required to install on 2g. i always thought they were the same but i guess not
All the G series turbos you find around here, or the FP3065/FP3052 turbos will bolt onto a stock mitsu manifold..14B, 16G, 18G, 20G, s20G, etc....they're mitsubishi turbos...thus they'll fit mitsubishi manifolds.
The t3/t4 is a Garret turbo, therefore they use Garret flanges...you'll need an aftermarket manifold for those types of turbos. They're usually also cut for external wastegates on those type manifolds.
You might also want to buy a 2g install kit for your new turbo...comes with oil lines/fittings/gaskets I believe...
2Gs came with Garrett T25s, is that to say that the T3/T4 will bolt up to 2Gs directly?
Precision turbo and agp have bolton t3/t4 turbos for the stock manifold. just gonna need new oil supply line for $80.
