t25 turbo on a 420a
ameclipse
Jul 9, 2005
portsmouth, Virginia
OK here is the deal were exactly do i plug the oil feed to the head i know i can run the feed to the oil pressure sensor but i got a kit from slow boy and it isn't long enough to go to the oil pressure sensor and i don't want to spend another 62$ on another hose to make it longer any pics would help alot Ive been told i can put it to the head i just don't know were. thanks
I noticed you didnt want to spend 60 bucks.Are you aware of the damage you can do to the motor by putting a turbo on like lifting the head,60 bucks will be a drop in the bucket.good luck :thumb:
you have no choice. the oil pressure sender is the only pressure tap source that i know about. get a longer braided hose. check ebay. i see alot of braided -3 or 4 an hose for a good deal. pm me for and more questions i will help you out dude.
ok im going to break down and get another hose to reach the oil pressure sender. oh well beats blowing the engine or turbo. im going to hit you up selmerguy if i got any more problems :thumb:
