T25 spools up quicker, but car letargic?
Siral3x
299
Mar 2, 2006
Ludington, Michigan
My engine has 158K miles on it :), and it's due a rebuild.
I fixed the Idle Surge by changing the ISC, now the car acts weird again.
The T25 seems to spool up quicker, but the car got a little bit letargic??
I'm thinking boost leak?? I want to perform a boost leak test anyway...what do I need to do it?? I'm assuming the car has to be turned off, and somehow pump air in the turbo inlet..while listening for leaks? or how do you guys do it??
What else should I chk??
thx
TheRealist said:
boost leak on a t25?? higly unlikely enless something tore or needs to be tightened.
Why would the turbo change the odds of having a boost leak. 9 times outta 10 the problem with a boost leak IS a loose clamp or a tear in the stock tubing. I would run a boost leak test and see what come's up. You need to pressurize the system and see where air leaks out.
vfaq.com has the how-to on making a boost leak tester check that out. pretty easy 1 trip to lowes/home depot.
Yes faster spool but less power sounds like a boost leak. Remember if the turbo cant put the air efficently into the engine, the engine cant make the exhaust to continue spooling the turbo and making power!
thx
You mean lethargic?
Yes stock boost.
Chief Brody sorry for my bad english dude...I'm from Europe...got maried with US chick a couple of months ago.
'Lethargic'..that's what I was gonna say :) haha..I learn english also on this forum LOL :) wiked :D
Ahhh...miss driving my 1G Turbo Convertible, never really had problems with it! For some reason I don't see any on the streets in Michigan..
