T-28 question is this possible?
It's all in having the right combo of parts and a great tune.
Those are some pretty high numbers for a t28 on pump gas though.
If i was serious about buying it, i would like to see a dyno sheet in person, because you know he didn't wipe with it and flush it down the toilet!
That pinstripping looks like he took some yarn and glued it all around the dashboardWTF It's confusing cause you either get that kind of poser garbage OR a fast car. He is unique in that he has merged both a fast and horribly tasteless car in one package.
I'd imagine an EVOIII 16g could put out 400 w.h.p. without much trouble. I'm impressed with mine:D
10's would make him one of the fastest guys on that turbo and he would have to have a lot of weight removed. That turbo could produce 350+whp but race gas or meth would be needed. I say he is a little full of it. Ask him for time slips and dyno sheets.
Ok now the guys saying he has a 1/4 mile slipe for 10 sec on that setup. now I looked and FP said with that turbo you could only get the high 11's
I'll clear this up, it's NOT a T28 or Big28 or any 28. I just reviewed pictures I have of the turbo. It's a Big16g compressor in a T3 compressor housing, a Garret T28 9 bladed 76 turbine wheel found on the Big28, and a machined out T25/T28 turbine housing. Again, it is not a T28.
Regardless, high 10s on 350whp? This car would have to be extreeeeemely light and have a good driver.
So its going to barely flow more and spool slower. Still comparing apples to apples.
I have that turbo and had similar mods at one point, minus cams. The car was auto but definitely was close to 350awhp at 23psi, 22* timing on E85. 0-60 in the low-flat 4 second range.
That was tuned to the edge though, and cost me the stock 7 bolt from cylinder pressure :coy:
