Swapping Non Turbo Parts for Turbo parts
dunneracing58
Mar 20, 2007
South Chicago Heights, Illinois
91 n/t 2.0 DOHC Eclipse. Can my non turbo parts be swapped for turbo engine parts" How much of the internals of a turbo motor is different from mine. This car is a race car, so I cannot do any visible mods, or else i would just turbo it. An example of a swap would be a turbo head with the turbo cams, valves, ect. Is that any different from my current head and would this be a likely power gain? Thanks!
If you are trying to squeeze more power out of your motor you can use the turbo parts off of a turbo car. There are write-up for it on here just search.
The difference between our nt motor and the turbo 4G63 is the pistons, no oil squirters, different intake cam, and fuel system. If you want to boost you have to atleast make sure you swap over to the fuel system from a turbo car and use the matching turbo., and also change the ECU to a turbo one.
