swapped axle now car shakes while turning
whe3ls
910
5
Jun 23, 2008
spokane, Washington
so i swapped out a clicking worn passager side axle in my buddys 92 awd auto. we to napa to a new axles for both sides. the axles i pulled out seemed to look slightly shorter than the napa axle.
this is the axle i used
NAPA AUTO PARTS)
should i try tis axle. it is slighly shorter
NAPA AUTO PARTS)
Your links don't work for me, but I'd suggest measuring the original Vs the replacement and if they are different, make a note of the difference and talk to NAPA. Since the part is now used, return may not be an option, but if there's clearly an error, check it out.
  • Wanted 6 bolt NT water pipe
    • chrisman287
