Car shakes at all speeds
Brandon Mau
Supporting Member
2024 DSM Shootout Class Winner
774
698
Mar 5, 2008
Fort Bragg, North Carolina
I just pulled motor and tranny out and re-installed. So after adjusting idle and making sure no leaks it was time to test drive. When I start out it's a light shaking. The higher the rpm's and speed the worse it gets. This shakes the whole car and seems to be coming from the front end. I replaced my cv boots and transfer case seals. I have checked everything 3 times and the mounts are all tight tranny bolt are tight. Wheel bearing bolts, lug nuts and shock tower bolts tight. Before I took this apart everything was good no shaking while driving. Now there is no shaking at idle only when I drive it. It feels like the driveshaft is out of whack but i did not remove it. Any suggestions would be great thanks guys.:banghead:
Make sure verything is right. Double/Tripple check everything. Im sure youll find it with a little investigation.
Found the problem soemhow one of the bearings c-clips desinegrated and well the rest is history. The bearing race was wedged in the case on the tranny. Never seen that one before.
  • Wanted 6 bolt NT water pipe
    • chrisman287
