Swap MHI 16g housings on Subaru 16g
2G_DSM_Kid
Mar 13, 2013
Mead, Washington
Hello I'm newish to turbo cars so I had my 16g blow up on me the other day. I was wondering is it possible to take the housings off it as they are in perfect condition and just use them on my buddies 16g that has the aftermarket Subaru housings on it. Would this work or are internals and dimensions of different 16g's different
found out it was a ebay turbo so i'm not touching it.
Taking my evo3 apart I notice the hot side the seals apparently did't seat right when installed but it also seems that maybe my turbine shaft is a little scuffed where the seal is and on the hot side bearing side. also the bearing housing seems to have a groove where the bearings go and where the seal sits.
My question is I can get a 14b off my friend for cheap can I swap the turbine and the bearing housing I have seen that they could be the same, but I want to be sure.
