suspension question
time4anotherdsm
May 3, 2005
new york, New York
hi. I have a set of eibach springs. two of them have model numbers 0700.250.0500 and two have 0700.250.0350. What I need to know is can these be used with just shocks or do they need to be used in conjunction with coilover sleeves (ground controls)? I don't knwo too much about suspension, so I'm not sure if these can be used with just shocks or not. Thanks
Tom
What I recommend doing is calling eibach, and seeing what series of spring that is i.e. prokit, sportline, etc...
Post back with the spring series and you'll get an answer quick. Also, what kind of suspension are you looking for? Do you want performance or looks?
they are race springs. "ERS Catalog
2.50" ID Springs"
Part Number Lo-inch Di-inch C-lbs/inch Sc-inch Fc-lbs WT-lbs
0700.250.0350 7.00 2.50 350 4.24 1483 2.31
0700.250.0500 7.00 2.50 500 4.06 2031 2.71
can these be used alone?
Yeah. On stock struts it won't ride very well though. And that's a pretty big drop.
  • For sale 4G63 Groden alum rods. Set of 4 with ACL bearings
    Groden aluminum rods. Set of four. 22mm small end. With ACL race rod bearings. Locating...
  • Wanted 1g Harness
    Wtb 1gb fuse box harness
    • 92AWDHX40
  • For sale 2g 2G Water Pipe
