Supporting mods for a EVOIII 16G
TurboBird
110
Feb 14, 2004
akron, Ohio
Ok, I did a search and came up with nothing. So what supporting mods would I need to have on my 95 Talon AWD to RELIABLELY have an EVOIII 16G installed on my car. I say relaible, b/c I am not putting the it on today or anything, but it is one of my final mod goals. Right now all I have is UICP, K&N air filter, and 1G BOV. What else would I need?? Thanx
You really must not have searched very hard. There are literally HUNDREDS of threads about the Evo 16g. Not to mention the tuning guide, which is linked at the top of every page. To sum it up, you'll want a FMIC or larger Sidemount, 550cc injectors, an upgraded fuel pump, and some kind of upgraded Fuel Management such as a SAFC, GM MAF Translator, and a Pocketlogger.
BTW - your sig won't sit well with the moderators, either. You might want to get rid of that text ASAP.
I did search, but you are right, I didn't spend an hour searching or anything, I was just taking a break from some HW. But I will check out the tuning guide I guess then. Thanx about the sig warning.
660's injectors
190 pump
3" exhaust
FMIC
cams
fuel control
logging program
boost gauge
boost controller
clutch
I'm sure there's some more, but enough people have already told you to search and use the tuning guide.
all of what they said if ur plannin on runnin over 16 psi. front mount helps w/ the weird hot start problems. and don't forget the port the turbo and do the 34mm flapper upgrade, that is a must....trust me.
sorry Coup D E'Tat, but u don't need cams for this turbo and 550cc injectors are plenty.
