Super AFC 2 Question
DSM_23
281
Nov 17, 2002
Springfield, Missouri
alright i have had my afc in my car for a little over a month now, and have tuned my fuel correction settings before but the other day i went to tune my correction and i noticed it said "omit" on the screen wherever the % of correction should read. It doesnt say anything in the book about this, and ive searched but nothing similar pops up, anyone else have this problem? Because i cant tune my afc at all it just reads omit, but it puzzles me because just a couple weeks ago i was able to adjust all my fuel settings. Any help on this would be great
justin
SOUNDS LIKE SUMTHIN IS WIRED WRONG. MAKE SURE YOU CUT THE BLUE WIRE WITH THE YELLOW STRIP ON IT AND HOOKED PINK TO ONE SIDE AND ORANGE TO THE OTHER. ALOT OF PEOPLE FORGET TO CUT THAT ONE
Thats what I found on the problem. Not much else is said about this.
You may want to check apexi's site but I checked it and didn't see anything about OMIT on their site. Just drop'em an email.
yes my connections should be very secure, but, then again strange things do happen, but if anyone else has any ideas that would help, but otherwise, ill drop apexi, an email, thanks
justin
I just had the same problem happen.
I could adjust my setting before, now its like 2 weeks later and it says OMIT where the % should be
Did you every find a solution to this? I have everything soldered, and had it working fine before.
Very puzzled :confused:
