1g super apexi afc 2 install help
Spoolin18
836
Feb 2, 2009
Albany, Kentucky
Can anyone please point me in the right direction, or know a link, cause I can't find one.
If you could just speak it in plain terms..IE..red wire goes to gray wire...etc..
Thanks.
Follow the VFAQ instructions when it comes to hooking up the RPM wire. If you follow Apexi's instructions to connect it to pin #54, you end up having to set the AFC to "2-cylinder" mode to get the rpm's to read correctly. Instead, use pin #21, crank sensor, as shown in the VFAQ instructions.
Jeff O.
http://www.dsmchips.com
SUPPORT: DSM Chips :: Index
