super afc??
venumnos
96
Jul 15, 2005
north miami beach, Florida
ok so i'm gonna go with the rc 550cc injectors and most probably insted of the big 16g i think i might just get the 20g but dont really know what afc to get the dsm link is just too much is the apexi super afc 2 SAFC any good????? worth it?? and is the walbro 255 too big?? thanks (2g gst)
The walboro 255 is just fine, a bit noiser than stock but it flows good. The same goes for the SAFC2 should be fine for your application. Easy instillation and easy use.
If you don't plan on going to larger injectors later then you'll be fine with the SAFC2. If there's any possibility you'll want to get more out of your car than the 550's can handle, just bite the bullet and get an EPROM ECU & DSMLink now. If by any chance you already have an EPROM ECU and a laptop computer, just get DSMLink since it's got datalogging too..
ok cool thanks for the advice but for now 550 is the largest i'm gonna go with for now untill i do the 6 bolt swap then i'll probably get the EPROM ECU so i guess when i do that i'll get the dsm link as well but thats not gonna be for a while i think.
