Sunroof Cover
Largo-W
Oct 12, 2011
Kraków, Europe
Hi,
Can anyone help me, how can I take off the interior plate of sunroof cover, which can be hide sunroof? In this plate, one of my friend when is drunk, broke piece of one side in this, how can I take it off to repair it?
Repair it will be easy, some glue and fix, but how take it off? :)
If anyone have photos, I'll greatful :hellyeah:
Best regards,
Largo
If you're talking about the sliding cover on the inside, which I think you are, open your sun roof part way so you can still put your hand between the glass and the exterior metal. There are spring-loaded pins on each side of the sliding panels. 2 pins per side, one forward, one rear; on both sliding panels. Once you take the rear panel out, the front one is easier, and done the same way.
OK, if I understand You this shouldn't be truoble of taking it off.
Thanks, I hope that I can handle with it :hellyeah:
Shouldn't be, but anything can happen. The main issue is getting the glass to slide into the right possition for your hands.
Hmm, so glass cover must be parted out?
If I understand You, I didn't take glass of, but take off sliding panels.
Thanks for this advice with the sunroof. I've been holding installing my slide cover for the longest time and knocked this out really quick!
